AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Lwpolyline not filling
3 REPLIES 3
kburgy
325 Views, 3 Replies
I have a drawing that I'm having issues with, all of the Lwpolyline that we have in our drawings are not filling in the arrow part.
I have checked to verify that the fill is on, fillmode is on, Apply solid fill is on on the Display tab of options.
It isn't a leader arrow, but I did verify that the Arrowheads are all selected to Closed filled.
Regen does nothting as well.
Any other thoughts.
3 REPLIES 3
Alfred.NESWADBA
in reply to: kburgy
polyline-widths are not visualized as filled when you don't look vertical onto the object-orienation.
Try command _UCS and then object ==> click onto the poly (that creates a ucs that is parallel to the entity-orientation), then run command _PLAN and option for current ucs. ==> is the lwpoly now filled?
If not please upload a DWG and not a PDF as we can look more into details of your object and ucs and sysvars.
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
kburgy
in reply to: Alfred.NESWADBA
That did not seem to work. our UCS icon never changes, I have attached a portion of the problem file.
Alfred.NESWADBA
in reply to: kburgy
command _PLAN with option _W
Or if you have the viewcube visibile: click on "TOP"
- alfred -
Alfred NESWADBA
”Boost
