AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Loaded acad map 2011 but no map menu!
8 REPLIES 8
Message 1 of 9
1985 Views, 8 Replies
For some reason i have no map menu in my acad MAP 2011!!!!!!!!!
8 REPLIES 8
Message 2 of 9
What workspace are you using? Or better question what prior version were you
using?
Murph
http://map3d.wordpress.com/
"sortego" wrote in message news:6396878@discussion.autodesk.com...
Message 3 of 9
Using map classic as workspace; coming from map 2010.
Message 4 of 9
Either the cuix is corrupt or the workspace was edited. Do the map commands
still work. If so just go into the CUI and add the map menu. If none of the
map commands work (at command line) then is a bad cuix or failing to load, a
repair is the quick fix for that.
Murph
"sortego" wrote in message news:6396991@discussion.autodesk.com...
Message 5 of 9
Another thing, at the top of my screen, it shows "AutoCAD 2011" instead of AutoCAD Map3d 2011
I just cant figure out whats going on here.
Message 6 of 9
Do you have AutoCAD Map3D installed? Look in the program files is there a
complete folder for AutoCAD Map3D 2011.
C:\Program Files\Autodesk\AutoCAD Map 3D 2011
Murph
"sortego" wrote in message news:6398826@discussion.autodesk.com...
AutoCAD Map3d 2011
Message 7 of 9
yes ther is.
Message 8 of 9
Open the acad.exe from there and see what you get?
Murph
"sortego" wrote in message news:6399004@discussion.autodesk.com...
yes ther is.
Message 9 of 9
Sounds like it attempted to start Map on a profile that does not exist. What it will do is open straight Acad without any map functions. I've fixed it by going into options, profiles. Re-naming the 'unnamed profile' to something meaningful, I use 'Stock'.
Then add the /p stock switch to your shortcut. This should start map up properly.
”Boost
