AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Line style
15 REPLIES 15
Message 1 of 16
978 Views, 15 Replies
Line style
Hello!
Who can help me? I want to creat a line style for feature objects (line object) wich symbols only on the vertex of the line. How can I do it?
Tags (1)
15 REPLIES 15
Message 2 of 16
parkr4st
one way shown in the attachments.  is this for display only or some other reason?
Message 3 of 16
parkr4st
in reply to: parkr4st
How I did the display manager. two uses of same shp file #3.  and with the line work layer off #4.
You could also get the nodes at the ends of lines as points and style the points in a seperate layer.
dave
Message 4 of 16
Thank you, parkr4st, for to try help me!
But I don't want to creat seperate layers. I want to do it only on liner layer. An example, I want to creat a power trust which was shown  on the picter.  I can to make a liner layer which symbols (blocks). But in AutoCAD Layer Style Manager we can do it by giving interval between symbols. If I want to give a symbol only for the vertex of the line, it is impossible. Have any way to creat style like that?
Power trust
Message 5 of 16
parkr4st
set style like this if i understand what you want
Message 6 of 16
No, this method, which you show, inserts the symbol only to the start and end vertexes. But I need to insert it to all vertex
Message 7 of 16
parkr4st
mapimport, explode the poly lines to lines, new sdf or shp and apply the style.
dave
Message 8 of 16
antoniovinci
Without creating any new linetypes, here's  a free tool doing what you wish, sir.
Message 9 of 16
But I thing that is not normally cartographic method. Because, every power trust must be one whole polygonal object and one raw in database table. Thank you very much, parkr4st, for trying to help me. I understand that in AutoCAD Map have not cartographic (styling) function like that......Smiley Embarassed
Message 10 of 16
parkr4st
Binnat
what is a power trust so I will know in the future?  i haven't heard the term.
dave
Message 11 of 16
Oh, excuse me, please! I am sorry! I have wrote term wrong.
I  want to say "truss". I speake about an elecrtic power truss (metallic construction for electric lines or tower):
Power truss
Message 12 of 16
Hmmm, I thing it is impossible what I want to get...........Smiley Embarassed
Message 13 of 16
antoniovinci
Did you try what advised in the post 27-08-2012 11:48 AM ..?
Message 14 of 16
in reply to: antoniovinci
Yes, I did. But this your method, inserts the symbol only to the start and end vertexes of the polyline feature. But I need to insert it to all vertex..... The problem in that...
Message 15 of 16
antoniovinci
  1. explode the poly
  2. run that wonderful lisp to get symbols in every vertex
  3. _copybase or _wblock them
  4. undo before the explosion
  5. _pasteorig or _insert the symbols back
The end, sir.
Message 16 of 16
Thank you, antoniovinci, for trying to help me! Don't trouble in this problem. Because, I understood that it is impossible in AutoCAD Map. I can't use your method, because you offer about drawing objects. I can't apply they to my spatial feature classes (digital map).  But for all that thank you very much, for all informations.........!
”Boost
