AutoCAD Map 3D General
Member
ENRICO_CONNECT
Message 1 of 8 (745 Views)
LINETYPE PROBLEM... NEED HELP!!
745 Views, 7 Replies
06-07-2011 05:09 PM
Hey,
I have a massive problem with my autocad map 3d's linetype scale...
Problem is caused from creating an primary viewport "construction plan", then creating a second viewport "detail plan" and zooming in on the detail plan viewport.
My line type in the detail plan turns into ------ LV  -----  as apart from the normal size of -----LV-----.
I've tried everything form psltscale, lt scale, msltscale (i think), audit, recover, basically everything i could.
NOTE: This problem is only oon my pc, and none of the other pc's in the offfice do this. I use classic autocad and have customised my buttons etc.
Thanks.
Enrico
Sinc
Message 2 of 8 (740 Views)
Re: LINETYPE PROBLEM... NEED HELP!!
06-07-2011 09:21 PM in reply to: ENRICO_CONNECT
Standard usage is to set PSLTSCALE = 1, MSLTSCALE = 1, and LTSCALE = 1 or LTSCALE = 0.5.  Then linetypes print the same in both primary and detail viewports.
Sinc
Member
ENRICO_CONNECT
Message 3 of 8 (738 Views)
06-07-2011 10:12 PM in reply to: Sinc
HI,
I've tried all of those line type settings and the attached picture is the outcome. Usually, as standard the LV in the attched picture is a lot larger. The only way  to reverse it to hold ctrl+z unitll the most of the work is reversed.
Cheers
Member
ENRICO_CONNECT
Message 4 of 8 (736 Views)
06-07-2011 10:14 PM in reply to: ENRICO_CONNECT
hi again,
attached is the lv line type from another drawing prior to the pronlem occuring.
Cheers,
Murph
Message 5 of 8 (717 Views)
06-08-2011 04:28 AM in reply to: ENRICO_CONNECT
Check your text style and font used for the Standard text or what ever the line type definition is using.
Murph
Supportting the troops daily.
Member
ENRICO_CONNECT
Message 6 of 8 (705 Views)
06-08-2011 06:36 PM in reply to: ENRICO_CONNECT
Is there a way to get the linestyle details? I mean, extract the line type style from the drawing. I've tried through design centre.
Reason for this is i will try to make another line type and just replace it.
Cheers
New Member
mr.dan
Message 7 of 8 (599 Views)
10-06-2011 01:03 PM in reply to: ENRICO_CONNECT
In "Manage Text Styles..." under Annotate tab/current txt style, Standard size should be uncheched for Annotative and Height should be 0.000.
New Member
harold.jones
Message 8 of 8 (389 Views)
12-12-2012 02:39 PM in reply to: ENRICO_CONNECT
I know I am resurrecting an old post, but just wanted to thank Mr. Dan and Sinc for posting their responses and that screen snapshot.  Thank goodness for Google, too.  I had learned about LTSCALE and PSLTSCALE before, but never knew about MSLTSCALE.  The real happiness came when I discovered my STANDARD text height was set to 25 in my Text Style dialogue box and it was causing my OH E and W linetypes to be unuseable.  Thanks again.
-Harold
You are not logged in.
Ask the Community
