Sorry, if I repeat topic but I can't find any solution here.
Do you know how to join atributes from xls/xlsx to table in shp file?
I attache some sample files.
I have shp with 3 poligones. Each has two atributes in the table. I prepared some table in excel. Now I want to join this file to shp's table.
Do You have any Idea how to do this?
Should I connect this file though FDO? (ODBC)
First create a view in the Excell file.
Next use the Windows ODBC admin to create an odbc connection to that speadsheet/file
Then in Map3D use FDO to make a ODBC connection and select the odbc connection you created in the ODBC Admin.
Then you can create a join to the FDO connected shp file provided you have a command field in both.
Beware the version of Map3D, MS Office, and 63/32 bit os has a lot to it working.
