AutoCAD Map 3D General
Member
LuisCollazo7470
Message 1 of 4 (188 Views)
Issues attaching files from 2006 AutoCAD Map to 2013 Map 3D
188 Views, 3 Replies
02-14-2013 09:16 AM
We are moving from 2006 AutoCAD Map to 2013 Map 3D. When I do an overlay of files in 2013 Map 3D which was
(X-REF) in 2006 the files don’t align, some do some don’t. I didn’t have that problem in 2006 or any other software. I have tried adding a cordinate system to the file to see if it mattered but it didnt unless I'm doing it wrong. I have just started working with 2013 Map 3D, any advice would be greatly appreciated thanks.
Valued Mentor
parkr4st
Message 2 of 4 (167 Views)
Re: Issues attaching files from 2006 AutoCAD Map to 2013 Map 3D
02-15-2013 01:50 AM in reply to: LuisCollazo7470
What type of files and your procedure to overlay them?
Member
LuisCollazo7470
Message 3 of 4 (157 Views)
02-15-2013 07:44 AM in reply to: parkr4st
My files are .dwg and I'm using attache DWG to overlay , The file was showing up on the File References area but not overlaid on the other file so I zoomed to full extents and noticed it was there but in a deferent location. I also get a notice "New Layers were found that need to be reconciled" I also added a coordinate system but how do I know which one is in the right location. Thanks
Valued Mentor
parkr4st
Message 4 of 4 (141 Views)
02-17-2013 06:01 AM in reply to: LuisCollazo7470
I would check each file to determine if it indeed spatially located correctly for starters. You may need to find a base layer that you are abslutely sure is correctly geo referenced to compare each dwg to. After that you can try the overlay again, however perhaps you could _mapexport each to a sdf file and use data connect to bring them into Map2013.  If the work all aligns correctly then your data should be ready to use.
You are not logged in.
Announcements
Need installation help?
Ask the Community
