Patrick,
I have not understood your problem clearly. If you can explain a bit
more (possibly send me a sample SHP file by e-mail), I am willing to
take a look and let you know.
Regards
Rakesh
Patrick wrote:
> I think I found the systematic problem related to the above error when
> trying to do a file translation. If I select a specific directory to
> find the files to use for an import a a shape file and run an import,
> then try to go to a subdirectory of the original directory I get the
> above error. I can go up two or more directories and select that
> directory, then move back down the directory tree,and it works OK. I
> still haven't overcome the shape file problem where the object data
> table gets forgotten when the file is imported.
> Thanks
> Patrick
Four Dimension Technologies, Singapore-India
Advanced AutoCAD customization for the Engineering/Mapping/GIS/AEC
Work smart NOT hard
Get GeoTools @ www.4d-technologies.com/geotools
