AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Internal Error UNDOCMD 3
2 REPLIES 2
Marpe
729 Views, 2 Replies
I'm having some trouble with my fresh installation of Map 3D 2007. I'm having sistematicaly a Internal Error UNDOCMD 2/3.
I tried audit's, recover, etc. Also tried new hardware drivers.
It's a HP xw4400 WKS fresh new.
Help needed!
TIA
Marpe
2 REPLIES 2
kylei7449
in reply to: Marpe
I have not found an answer for this most frustrating error. I can't save a stinking file. I'm using 2010, so it appers to be happening across multiple Autodesk platforms. IF anyone at Autodesk has an answer (not a "try this") please share, thanks.
Murph_Map
in reply to: kylei7449
You might try starting your own thread with more detail instead of tagging on to an old thread from 2007. Include you system specs and an screen capture of the error. What coomads you were using and what you were doing help find answers quicker.
Murph
Supporting the troops daily.
”Boost
