AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Install of AutoCAD Map 3D 2013 Stalls at Autodesk Material Library 2013
6 REPLIES 6
gluckett
2655 Views, 6 Replies
Hi All, has anyone come across this installed 32bit AutoCAD Map 3D 2013?
My install fails at the AML 2013 - Low Rez and I can't install Map at all.
  I don't think there is an option to no install the Material Library...
Here is my log file from a few minutes ago...
2012/5/29:12:31:55 gluckett PRAGUE Installing Autodesk Material Library 2013 - Low Resolution:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_Map_3D_2013_English_Win_32bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/5/29:12:32:47 gluckett PRAGUE Install Autodesk Material Library 2013 - Low Resolution Failed Installation aborted, Result=1603
6 REPLIES 6
thepworth
in reply to: gluckett
Is your virus protection disabled while you install?  It may be the culprit.
gluckett
I wish it were that easy!
I tried installing that library manually:
C:\Autodesk\AutoCAD_Map_3D_2013_English_Win_32bit\Content\ADSKMaterials\2013\ILB\BaseImageLibrary2013.msi
But it still Fails:
I wish I could tell AutoCAD Map 3D 2013 not to install this component when installing and I would be golden.
gluckett
More details:  this is where the install of the Materials fails:
InstallShield 16:42:06: Invoking script function Luc_Install
InstallShield 16:42:13: CallScriptFunctionFromMsiCA() ends
InstallShield 16:42:13: Cleaning up temp file C:\Users\gluckett\AppData\Local\Temp\{4C4693A5-5207-4576-B590-893E8056BF79}\ISRT.dll
InstallShield 16:42:13: Cleaning up temp file C:\Users\gluckett\AppData\Local\Temp\{4C4693A5-5207-4576-B590-893E8056BF79}\IsConfig.ini
InstallShield 16:42:13: Cleaning up temp file C:\Users\gluckett\AppData\Local\Temp\{4C4693A5-5207-4576-B590-893E8056BF79}\String1033.txt
InstallShield 16:42:13: Cleaning up temp file C:\Users\gluckett\AppData\Local\Temp\{4C4693A5-5207-4576-B590-893E8056BF79}\_isres_0x0409.dll
InstallShield 16:42:13: Cleaning up temp file C:\Users\gluckett\AppData\Local\Temp\{4C4693A5-5207-4576-B590-893E8056BF79}\setup.inx
CustomAction LaunchLucEXE_2012 returned actual error code 1603 (note this may not be 100% accurate if translation happened inside sandbox)
Action ended 16:42:13: InstallFinalize. Return value 3.
Action ended 16:42:17: INSTALL. Return value 3.
Action ended 16:42:17: ExecuteAction. Return value 3.
Action start 16:42:17: SetupCompleteError.
Action ended 16:42:32: SetupCompleteError. Return value 2.
Action ended 16:42:32: INSTALL. Return value 3.
=== Logging stopped: 5/29/2012  16:42:32 ===
MSI (c) (6C:70) [16:42:32:189]: Product: Autodesk Material Library Base Resolution Image Library 2013 -- Installation operation failed.
MSI (c) (6C:70) [16:42:32:189]: Windows Installer installed the product. Product Name: Autodesk Material Library Base Resolution Image Library 2013. Product Version: 3.0.13. Product Language: 1033. Manufacturer: Autodesk. Installation success or error status: 1603.
Alfred.NESWADBA
1603 has sometimes to do with Framework (so install Framework 4 before starting AutoCAD-installation) or with access-rights, so install AutoCAD with another user-account that has full local admin-rights and UAC is switched off and the SETUP.EXE is started with the right-mouse-button ==> "Start as Administrator".
Also verify what processes and services are currently running during installation, e.g. Antivirus-software (as already mention) or some defender or a backup-process ... disable all that is not necessary for the OS and for the installation.
Good luck, - alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
gluckett
Thanks for the tips:
  •  turned off Virus Software
  •  turned of Firewall
  •  stopped all non-essential services
  •  installed .net 4 framework (already there since AIMS 2013 is installed)
It truely is the this MSI that is the issue.
 (C:\Autodesk\AutoCAD_Map_3D_2013_English_Win_32bit\Content\ADSKMaterials\2013\ILB\)
I wonder if this MSI is corrupted on the install DVD/Download...
gluckett
ok, since the Low Rez MSI was the issue, I hacked the Setup.ini found in this folder:
C:\Autodesk\AutoCAD_Map_3D_2013_English_Win_32bit/
I found the [CMILB2013] section that refers to the Low Res Materials around line 303
Commented out everything with Pounds # beneath the [CMILB2013]
I copy and pasted the [CM2013] stuff because Map 3D 2013 won't install without the [CMILB2013]
which effectively installed the high-rez MaterialLibrary2013.msi twice
Ugly, but at least I got past the corrupted Low Rez Materials MSI.
”Boost
