I have problem with deploying IM to SQL server 2012 Expres. Everithings runs OK, but when I try to update industry model schema (water, waste water, ...) I got this error:
Structure update problem occurred during update.
Message:
Adding the feature class 'Contact' failed.
Specific Error:
NEXT VALUE FOR function cannot be used within CASE, CHOOSE, COALESCE, IIF, ISNULL and NULLIF.
Plug-in: Water Data Model (2.5.0)
1 Structureupdateplugin(s) failed.
Same error (NEXT VALUE FOR ...) appears when i try to manually create new feature class in administrator.
Any ideas how to solve this ?
ACAD version: Map 2013 + SQL Server FDO Hotfix.
Solved by weibelt. Go to Solution.
Hi
Please have a look to http://usa.autodesk.com/autocad-map-3d/system-requirements/. Only SQL Sever 2008 R2 is supported.
Best regards
Tobias
