I'll try to import a text file with a string: pointnumber, easting, northing, elevation, discription, but I get very big blocks and attributes in my drawing. I use Autocad 2011 Map 3D, on a windows XP OS. I'll importing the text string with the import command. Easting and Northing are for the position. The Elevation, pointnumber and discription are attributes from a block. I can only choose a block: "Map_Survey_point" This is the only block I can choose. When I import the text, the scale from the importing blocks are too big. How can I change the size of the block and attributes? Anybode an idea?
You can use Quick Select "qselect" after you import the points then change the scale in the property palette. I have no idea why the default is so large or why they scale up.
Murph.
Thanks for your help. That is the solution. It works! Thank you very much.
Duncan
@d.kerkhoff wrote:Murph.
Duncan
You are welcome. 🙂
Hi mr kerkhoff,
I am new to autocad map....can you please show me how you imported text in your map ...I am having great difficulty i doing this.thanks
