AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Importing survey points with numbers in AutoCAd 2011 Map
7 REPLIES 7
Message 1 of 8
paduroiul
1379 Views, 7 Replies
How can I import survey points in AutoCAD Map. The points are stuctured like this (point number, easting, northing, altitude)
e.g.
52499.990.537499.983.388399.872
7 REPLIES 7
Message 2 of 8
antoniovinci
in reply to: paduroiul
Command: _AECCCREATEPOINTS then choose PENZ as point type (it works for me in Map2006, I hope in your 2011 too...)
Message 3 of 8
Murph_Map
in reply to: antoniovinci
In my 2011 I get this ---
Unknown command "AECCCREATEPOINTS".  Press F1 for help.
Mapimport then select ASCII point file works, however you may need to select the points(blocks) afterwards and change the scale factor in the property palette to 1.
Murph
Supporting the troops daily.
Message 4 of 8
paduroiul
I don't have the option "mapimport". I just have Map Setup and no option for ASCII import file
Message 5 of 8
Alfred.NESWADBA
Start command _MAPIMPORT, if that does not work you have either no Map3D2011 or you have an invalid AutoCAD-Profile. Type the command into the command-line press <ENTER> and let's see.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 6 of 8
paduroiul
in reply to: Alfred.NESWADBA
it works, but all the simbols and texts are really large Icouldn't rescale them
Message 7 of 8
Alfred.NESWADBA
Two options:
  • select one of the blocks, right-click ==> open in blockeditor, scale the content of the blockdefinition, close blockeditor with saving and run command _ATTSYNC one.
  • select all block-insertions, open the property-window (<Ctrl>-<1>) and set the scalefactor X/Y/Z to a value you want to have it.
- alfred -
Alfred NESWADBA
Message 8 of 8
paduroiul
It's working
Thanks!
Are there any options regarding scales, renumbering, modifying the elevation?
I don't know if you've heard of TopoLT, with this application you can do all of the stuff I've mentioned above.
Do you know any free lisp which does these kind of operations?
”Boost
