I am trying to import a .stp file using Map3d. I know I need to go to import, but there is no option for chosing a .stp file,
am I missing something????
Solved by Alfred.NESWADBA. Go to Solution.
I guess you can't, sir.
If you're in a hurry, zip and upload the .STP file here, ans someone will convert it for you.
@Anonymous wrote:I am trying to import a .stp file using Map3d. I know I need to go to import, but there is no option for chosing a .stp file,
You're not missing anything, Standard AutoCAD and Map3D do not support the STP format with out add-on(s).
I might of given out wrong info, the import of STP files was removed in some version but is back in the 2012/13 versions. So it depends on the version of Map3D you are using. Also if you post in the General AutoCAD forum you may get some help with it.
>> I am using AutoCAD map3d 2013 but I cannot find the import .stp files
No, it's not included in Map3D, but you wrote that you have someone with plain AutoCAD ==> and that (at least with 2012 or 2013) can import stp-files.
- alfred -
