File and instruction can be found on autodesk site
http://www.autodesk.co.uk/adsk/servlet/item?siteID=452932&id=7292811&linkID=6823983
Have tried loading OS mastermap set for my area, works fine up to a point where I loaded the tenth GML file ,then crashes badly with and unhandled exception error, have recovered this file but the whole drawing is now unworkable due to the length of time to run commands. Looking at loading each GML file individually but how you then manage it and use user only updates is a big ?
