AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Import geodatabase file into Map 3d 2015
3 REPLIES 3
erwebsite
3292 Views, 3 Replies
Is it posible to add a geodatabase (.gdb) file into Map 3d 2015. I know this was not available before and am wondering if this has changed.
Civil 3D 2014
Win 7
Tags (2)
3 REPLIES 3
braudpat
in reply to: erwebsite
Hello
Sorry I am not sure but I think that since MAP R2014 (32 bits only), you have a direct ESRI FDO driver able to connect to some GDB files !?
But you have to check or better wait to an other "ACAD MAP GIS Specialist" ...
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
phil_borycens
Hi there,
No, there is no change in 2015 to the way AutoCAD Map 3D connects to ESRI geodatabases. The same requirements still apply:
http://beingcivil.typepad.com/my_weblog/2014/02/working-with-esri-file-based-databases-in-autocad-ma...
Some workarounds are suggested in the above blog post in case you need them.
Phil Borycens
cedwards8511
Is the geodatabase on an ArcServer? If so, you may try using "ArcGIS for AutoCAD" to connect to it by adding the ArcServer as a GIS Service.
I haven't got our ArcServer running fully, so I haven't been able to try this. Please let us know how it goes.
”Boost
