AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Import features to dwg from SDF
3 REPLIES 3
pg002a
726 Views, 3 Replies
HI
I need a solution how to convert SDF line features to DWG, where only one feature converted to  DWG   and DWG is named after feature ID. So if i have SDF file where are 3 featured( ID's are 1,2,3) and i want to convert those features to three  different DWG files(one feature per DWG):1.dwg, 2.dwg etc.
How is the best way to do this?
Kajar
3 REPLIES 3
Murph_Map
in reply to: pg002a
One way is use Data Connect and connect to the SDF file but instead of adding it all to the map use the add to map with query. Then export that to Autocad dwg format, Repeat for the next and so on.
Murph
Supporting the troops daily.
parkr4st
in reply to: pg002a
open two maps or Map twice on two monitors, set the coor sys same on both, copy with base point from map one to map two, save as,  delete the pasted object and go get the next item in map one and repeat.
or map import, delete all but 1st object save as map1. undo, delete all but 2nd, save as map2, save as, etc
Dave
pg002a
in reply to: Murph_Map
I think i need some script for that so i can do all automatically.
”Boost
