HI
I need a solution how to convert SDF line features to DWG, where only one feature converted to DWG and DWG is named after feature ID. So if i have SDF file where are 3 featured( ID's are 1,2,3) and i want to convert those features to three different DWG files(one feature per DWG):1.dwg, 2.dwg etc.
How is the best way to do this?
Kajar
One way is use Data Connect and connect to the SDF file but instead of adding it all to the map use the add to map with query. Then export that to Autocad dwg format, Repeat for the next and so on.
open two maps or Map twice on two monitors, set the coor sys same on both, copy with base point from map one to map two, save as, delete the pasted object and go get the next item in map one and repeat.
or map import, delete all but 1st object save as map1. undo, delete all but 2nd, save as map2, save as, etc
Dave
