Hi everybody.
I have some problem with import SDF to dwg. Geometry in SDF is curve with mixed linear and arc segments.
But the result is not my expected result. (see image below) . All arc segments was imported not correctly.
I'm expecting my data is correctly in the sdf files, but some import mechanism not work properly.
When I make connection through FDO it's work ok.
Thank you for help.
Without having access to your SDF-file we can't play with your problem.
But if connection of this dataset via FDO works then connect it with FDO into a new file and then export the map as drawing. That will also convert the SDF-objects to AutoCAD-geometry type. Use command _MAPTOACAD or _MAPEXPORTCURRENTMAPTODWG
- alfred -
Hi Alfred.
Thank you for help. It's work correctly with geometry.
What about set convertion options?
There are only XDATA option available. My business need Object Data convertion.
Sincerely,
Michael
