AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Image coordinate systems transformation and rotation questions
3 REPLIES 3
rhdins
747 Views, 3 Replies
I have some UTM images that I need to convert to State Plane. If I import them into map with raster design and export them to the state plane coordinate system, they work just fine, but I can't figure out a way to get rid of the black wedge that it makes along the edges of images. Any ideas?
If I query them in using map I can transform the coordinate system, but then every time I open the drawing it takes like 5 minutes just to open.
What has everyone else done to use multiple images in a drawing and transform or convert the coordinate system of the images? Thanks.
3 REPLIES 3
in reply to: rhdins
If you don't need what's around the edges open it up in RD and copy/paste
into a new image. Select with a rectangle just inside the edges leaving out
the black wedges.
Murph
http://map3d.wordpress.com/
"rhdins" wrote in message news:6365836@discussion.autodesk.com...
rhdins
in reply to: rhdins
I don't think that would work, I have about 17 images that I am using, if I clip out just what's inside then that leaves a gap between all the images. If anyone has any other suggestions they would be greatly appreciated.
in reply to: rhdins
I have a solution that i have been using in AutoCAD MAP 2013. i am not sure what you are using.
For AutoCAD MAP 2013, once you "connect" the tiff file you might be observing the black background surrounding your image. In order to get rid of it open display manager and right click the respective tiff file connection and select "Edit Style".  A new dialogue window will pop up. Here you will notice a "transparent" button. Select it. In the new window select " Select <". Now select the back boundary which you want to remove.. Hit "OK". Now select apply in the "Edit Style" window dialogue. MAP will automatically remove the background for you.
Do share if it worked for you
Cheers
Jay
”Boost
