So I haven't done this in ages. When building an annotation template, in the block editor (annotation editor etc..); how do you take the length of a 2D line or pline to be the display of my template?
Doing a water system map and it would be nice to have a line length with the ' symbol at the end rounded to the nearest foot on each length of pipe.
thanks so much
Dave in Milwaukee
Hi Dave,
You'll want to follow a process like this:
http://docs.autodesk.com/MAP/2012/ENU/filesMTU/GUID-F786FFFA-3D45-4AB5-9170-2B92D0DAC4FE.htm
On step 9, look at the screenshot. You'll want to expand the Properties and/or Object Properties to take advantage of some of the built-in properties of your linework (like length).
@borycep wrote:Hi Dave,
Great Phil, now tell him how to do the second part and place the "foot" mark at the end and to round the length to whole numbers.
Thanks so much for the help both of you.
Murph, I found one of your old posts with some script to let me add the foot suffix on the end. Thanks so much for the help. The forums seem to deliver when no one else can figure it out.
I had forgotten about the MAPANNTEXT command as well. Got it my word doc now with the commands I don't use often but forget.
thanks again
@dudad wrote:Thanks so much for the help both of you.
thanks again
No problem there is also a way to round the length, ex. 124.567 = 124 with a few of the lisp functions if you need those ask.
