AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
How do I break linked polygons created from New Feature from Geometry?
3 REPLIES 3
Jfactory
402 Views, 3 Replies
Hello, I'm using AutoCAD Map 3D. I had some geometry that I needed to convert into a shape file, so I selected on the shp layer "New Feature from Geometry".  Everything converted to join the shape layer, but now it is all connected.  I want to move/edit individual polygons but when I go to select one it selects all of them.
I've noticed I can "create new feature" one at a time, but I'd really like to find how to unlink them after I've converted them in bulk.
3 REPLIES 3
Murph_Map
in reply to: Jfactory
New feature from geometery is designed to work one feature at a time. That allows you to add/edit the feature atrributes. To "bulk convert" you need to use the map export command.
Murph
Supporting the troops daily.
Jfactory
in reply to: Murph_Map
Thank you, Murph!
Murph_Map
@Jfactory wrote:
Thank you, Murph!
You're welcomed.
Murph
”Boost
