AutoCAD Map 3D General
Member
Message 1 of 4 (334 Views)
How can ı save complex styles for line features?Helpppppppppppppppp
334 Views, 3 Replies
07-30-2012 09:09 AM
Hi everyone,
I have to create complex styles for line features. This features like different road types and stream type.  When ı create my own style like on capture, ı want to import feature styles to other projects.
Please help about this subject.
In arcgis ı can get largely spread style library for polygon, line or point.
And ı can modify and resave this feature style.
But in Autocad map 3d it s very diffucult.
Please helppppppppppppppppppppppp
Employee
sebastien.baudin
Message 2 of 4 (232 Views)
Re: How can ı save complex styles for line features?Helpppppppppppppppp
10-02-2012 02:09 AM in reply to: 8643132
I think you will find some answers in the following article:
http://topobaseinsiders.typepad.com/the_topobase_insiders/2010/01/enhanced-stylization-line-styles.h...
Kind regards,
Sébastien Baudin
Autodesk Support Team
Distinguished Contributor
bingeomatics
Message 3 of 4 (224 Views)
10-02-2012 05:11 AM in reply to: 8643132
If you want to use your line styles or other symbols, you can first save your GIS layer as "layer" file right clicking on the GIS layer. And after it, you can import this "layer" file in other projects.
Binnat Khalilov
Valued Mentor
Message 4 of 4 (201 Views)
10-03-2012 06:54 PM in reply to: bingeomatics
one way..  create a .layer with one item styled as you like , ie a section of road line styled.  Copy that file and paste the  .layer file in windows explorer and change the name of the copy to preserve your orignal for another use., then drag & drop that into a map.  Right click the  layer in Display manager and create a new object.  the new object will acquire the style.  or if you have dwg objects select  create new feature from geometry  , select the objects and they will acquire the styling.  You could map import a sdf or shp and qselect and add it to the style layer this way.  erase the object you dropped into the map to remove it from the data set and check in.
dave
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
