I keep getting a Heidi Module load error. I have an old visiontek radeon 9600se video card and may need a new one but I can't find a list of compatible video cards with Map 2011. Is the Heidi issue related to the video card? Where can I find a list of compatible cards. I have AGP and run XP.
Pat
Once again I may have answered my own question. I think that somehow my directx got disconnected and that caused the error.
The first step to fixing the problem was to see if I even had Directx installed:
Check DirectX
To determine which version of Microsoft Direct X you are running:
I went to the Display tab and found that the DirectDraw Acceleration had been disabled. I enabled it and all is now OK with no Heidi errors.
Pat
RE: Where can I find a list of compatible cards. I have AGP and run XP.
I have had issues trying to locate this list in the past, but once you find it, it can be a great help.
You can find the list of Campitble Video Cards at the address below.
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=7107053&linkID=9240618
I hope this helps!
-J May
Autodesk made a change...
The location of the Hardware Graphics List has been relocated, in addition they changed the interface of the list to a detailed search.
You can find the list here:
http://usa.autodesk.com/adsk/servlet/cert?siteID=123112&id=16391880
Hopefully this helps.
Take care,
-JMay
