AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Global Coordinate System Variable
0 REPLIES 0
Message 1 of 1
405 Views, 0 Replies
I am using Map 3D 2014, 64 bit on Windows 7, with Carlson Software installed.
My problem is with the "Assign Global Coordinate System" in the task pane submenu. I set the system to the one I want, work within the drawing, save and exit. All seams fine. But every now and then I will open a drawing that I know for sure had the coordinate system set but a review of the setting shows no coordinate system set. It some how was reset to the default setting. I have chased this gremlin for months and can't find a cause. Anyone have an idea??
Ron Engbeg
0 REPLIES 0
”Boost
