AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Geomarker moves around?
3 REPLIES 3
gosparky
415 Views, 3 Replies
I have noticed that the location of the geomarker in my drawing has moved.  When I started the drawing and brought in 2 quads of topo contours, it was smack in the middle of the topo.  Then I started creating profiles off toward the top of the screen.  I noticed that the geomarker is now displayed toward the top of the topo instead of in the middle.  But when I scroll over it, it still lists the same lat & long as before.  Is this normal?
Thanks!
3 REPLIES 3
thepworth
in reply to: gosparky
think of it as a mindless reminder that you're working in a georeferenced coordinate system.  if it really bugs you, i think "georefmarker" or some similar command will shut it off.
antoniovinci
in reply to: thepworth
Yep, the command is GEOMARKERVISIBILITY = 0
thepworth
in reply to: antoniovinci
thanks it was late last night after a few beers 😉
”Boost
