AutoCAD Map 3D General Discussion
New Member
gjohnson
Message 1 of 5 (652 Views)
Geomap command will not load imagery
652 Views, 4 Replies
10-29-2013 09:45 AM
When i type in the Geomap command, i get the option for Aerial, Hybrid, Road, off. No matter which selection i make, the imagery will not load. I go to someone elses machine and open the same drawing, the imagery loads.Am i missing a setting somewhere?
Alfred.NESWADBA
Message 2 of 5 (644 Views)
Re: Geomap command will not load imagery
10-29-2013 10:40 AM in reply to: gjohnson
try to toggle hardware acceleration (command _3DCONFIG ==> manual tune) and if that does not help then try to either start with another AutoCAD profile or login to your Windows with another user account and try it there.
Let us know your test results then. :smileywink:
- alfred -
Alfred NESWADBA
New Member
gjohnson
Message 3 of 5 (637 Views)
10-29-2013 11:28 AM in reply to: Alfred.NESWADBA
Thank you for your response. I had to rebuild my profile. works fine now.
New Member
mgardner101102
Message 4 of 5 (560 Views)
11-12-2013 04:48 AM in reply to: gjohnson
I am experiencing the same problem.  I am unable to get any of the maps to load the imagery and when I start with a new, blank dwg file and select location, from map, I can not get the window to pop up for me to select the location.
Any suggestions?
Alfred.NESWADBA
Message 5 of 5 (547 Views)
11-12-2013 08:57 AM in reply to: mgardner101102
welcome @forums.autodesk.com !
Do you get the request for the file in the command-line instead?
If so you might set the sysvars FILEDIA and CMDDIA to 1.
If you are not asked for a filename, what does you Map3D do after starting the command? Does it hang, does it crash or is it just ready for the next command (like ignoring the current command?
BTW: how do you try to insert the image? Command _IMAGE or _MAPIINSERT or _MAPCONNECT?
- alfred -
Alfred NESWADBA
