AutoCAD Map 3D General
Moderator
Olga_Shevchenko
Message 11 of 17 (260 Views)
Re: GeoTIF Greyed Out in Layout
01-15-2013 03:40 AM in reply to: BrianHailey
The problem can be solved by this way. You could change a color that is transparent (use a lightest color).
Besides you could insert a JPG-image as a background.
Alfred.NESWADBA
Message 12 of 17 (248 Views)
01-15-2013 04:10 AM in reply to: Olga_Shevchenko
good workaround! Is there any description why this depends from a coordinate-system set or not set?
Another question: What can you do when you have to reference that object using FDO? There you can see the "transparency color" as option in the property window, but you can't change it.
[EDIT] found the setting within MAPWSPACE ==> FDO-Stylization [/EDIT]
But thank you for that workaround!
- alfred -
Alfred NESWADBA
Moderator
Olga_Shevchenko
Message 13 of 17 (227 Views)
01-15-2013 06:33 AM in reply to: Alfred.NESWADBA
it seems to me, that it doesn't depend upon CSS, rather upon GeoTiff. Look for the alpha channel, BlackColor  is transparent.
If FDO connection is used one needs both images to be pre-loaded, JPG is to be used as a background for GeoTiff
Look here, please
Moderator
Olga_Shevchenko
Message 14 of 17 (221 Views)
01-15-2013 08:10 AM in reply to: BrianHailey
Hi :smileyhappy:
If FDO connection is used, you need to change Trancparency Color here. )))
BrianHailey
Message 15 of 17 (196 Views)
01-15-2013 04:09 PM in reply to: Olga_Shevchenko
That seems to do the trick. Thanks!
I'm just glad that I only have six images to do this to and not 30 or 40. :smileyhappy:
Moderator
Olga_Shevchenko
Message 16 of 17 (183 Views)
01-15-2013 09:36 PM in reply to: BrianHailey
BrianHailey написано:
You are welcome :smileyhappy:
I'm agree with you, this is a very exciting activity... :smileylol:
Try to use _matchprop or use the FDO and combine all images into one layer
PS Don't use _MAPCSASSIGN (  don't set the drawing coordinate system to WY83-EF) while GeoTIFF is opened by FDO Connection and before this
Moderator
Olga_Shevchenko
Message 17 of 17 (159 Views)
01-16-2013 04:40 AM in reply to: BrianHailey
This is another way, but it does not work sometimes.
You are not logged in.
Ask the Community
