AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Gas line sliding mile classification
2 REPLIES 2
deetersmith
570 Views, 2 Replies
Is anyone else working on gas transmission classification using the "sliding mile" for the building count?  If so what procedure are you using.  At this point I have run the 660' buffer around the lines added the address/structure point queried to within the buffer polygon then select all the points along a mile of point to get a count.  Tedious but working so far.  I just wonder if there is a better way.
2 REPLIES 2
parkr4st
in reply to: deetersmith
it showed up earlier here
http://forums.autodesk.com/t5/AutoCAD-Map-3D/Challenge-to-any-Lisp-guru-to-help-me-beat-my-ESRI-Co-w...
Don't know if any conclusion was reached
Dave
deetersmith
in reply to: parkr4st
I can not find that there was a decision made.  If there is anyone willing to help with this it would be greatly appreciated.  I know I am not the only person dealing with the situation.
”Boost
