AutoCAD Map 3D General Discussion
Active Contributor
clemk
Message 1 of 7 (409 Views)
GIS data connection
409 Views, 6 Replies
03-12-2012 07:19 AM
We have this public server in Indiana that I am trying to figure out if Map 3D will connect to.  The directions on how to connect are here:  http://kb.iu.edu/data/aqfx.html
Can anyone verify / clarify for me if Map 3D 2012 is able to connect to this data?  I cannot get it to work, but I am not a Map / GIS expert by any means.
Thanks!
Product Support
SethHall
Message 2 of 7 (363 Views)
Re: GIS data connection
03-14-2012 12:34 PM in reply to: clemk
Hi Clem-
I would have to assume that if you were accessing this from within the confines of the University's network that you would not need a username/password. Do you happen to know these credentials?
Additionally since this is a ArcGIS server, ArcSDE would probably be the connection you would use in FDO. Also you may want to try this http://www.esri.com/software/arcgis/arcgis-for-autocad/download.html and see if that helps.
Seth Hall
Product Support
GCSO - CSS - FTS
Being Civil
Being Civil Twitter
Being Civil Facebook
Active Contributor
clemk
Message 3 of 7 (337 Views)
03-16-2012 10:20 AM in reply to: SethHall
Hi Seth,
Thanks for the input.  I have received this additional information for the public ArcSDE server on this site...
The account username is :inmap
The password is:wndrIN2day
The server name is: inmap.iu.edu
The instance name is: inmap
Oracle direct connection uses port:1522
Application connection uses port:8307
I have had no luck with Map 3D data connect with this information.  I get an error in Map of "unable to establish connection to provider.  FDO Provider entry point function 'CreateConnnection' returned NULL."
Would you kindly see if you can utilize this new information to connect to this ArcSDE server?
Thank you!
Clem
Active Contributor
dwolford
Message 4 of 7 (332 Views)
03-16-2012 11:14 AM in reply to: clemk
I tried to use the information you provided and failed.  I tried using ArcSDE FDO and WFS FDO and neither could obtain a connection.
Product Support
SethHall
Message 5 of 7 (328 Views)
03-16-2012 11:51 AM in reply to: clemk
By any chance are you runnign a 64-bit OS? If so please see this technical solution: http://usa.autodesk.com/getdoc/id=TS18800464
Seth Hall
Product Support
GCSO - CSS - FTS
Being Civil
Being Civil Twitter
Active Contributor
dwolford
Message 6 of 7 (319 Views)
03-16-2012 01:19 PM in reply to: SethHall
Yup that would be my problem, I am running 64-bit Windows 7 with 64-bit AutoCAD Map 3D
Active Contributor
clemk
Message 7 of 7 (291 Views)
03-19-2012 06:38 AM in reply to: SethHall
errr.  I remember that 64-bit issue... now that you reminded me :smileysad:
Thanks Seth.
You are not logged in.
Ask the Community
