AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Feature Line Styles
1 REPLY 1
ChadRoberge
398 Views, 1 Reply
Feature Line Styles
Anyone know if it is possible to edit feature lines join and end styles?  I have some compound lines that I would like to look like piping but the option for styling them is greyed out.  Just wondering if there is a way to enable these.  I have tried adjusted the plot styles but to no effect.
Again this is for feature lines not normal autocad entity lines.
Chad
1 REPLY 1
Hi Chad,
it is currently not possible to set these things up in Style Editor but it can be done by editing the XML structure of the layer file.
Have look at: http://trac.osgeo.org/mapguide/wiki/AdvancedStylization
The XML poperties you need to set are: LineCap and LineJoin.
More information available here:
http://topobaseinsiders.typepad.com/the_topobase_insiders/2010/01/enhanced-stylization-line-styles.h... (different topic but maybe helpful)
http://geospatialnavigator.typepad.com/geospatial_navigator/2010/08/topobase-tipp-stil-fr-linienende... (in german)
Good luck,
Rob
http://raumpatrouille3d.blogspot.ch/
”Boost
