Fatal error when using grip to select obect..
Crashes
some questions:
Additional info would bve helpful:
a) Screenshot from your crash
b) Data-Upload if you are allowed to show that
- alfred -
Program - 2012 Map 3D W/Raster Design SP1,64bit
Workstation - Windows 7 Enterprise SP1, Dell T5500, E5607, 8Gb.
Crashes/Fatal error anytime I attempt to select anythnig using grips.. Blocks, plines, text, anything..
Just started it this morning... Last week everything was great....
try to login to your pc/to your Windows with another user-account, then start AutoCAD-Map .... same problem?
What has changed on your pc since it was fully functional last time? Any updates from Windows? Was there anything installed in the meantime?
- alfred -
Tryed that, didn't make any disfference...
Reset the system var "GRIPS" to 0 then back to 1.... Fixed it.. don't know why...
Weird... but not surprising..
Thanks for trying to help!!!!
Thank you for the feedback!
I also don't understand the reason why this helped, but now we know that it's worth to try it! 😉
- alfred -
