AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Fatal error when using grip to select obect..
5 REPLIES 5
383 Views, 5 Replies
Crashes
5 REPLIES 5
some questions:
  • What AutoCAD-Map3D release do you have?
  • What Servicepack have you installed for it?
  • Is it reproducable (every time you click an item) or does it appear randomly?
  • What datasource-type do you use? SHP, SDF, SQLite, ....?
  • Where does this datasource com from, what software created this data?
  • Does that datasource contain polygons, arcs, points or mixed data?
  • Have you tried to convert it to SDF and continue that way?
  • Have you tried to connect the data into a new drawing?
  • Have you checked the current drawing with _AUDIT (before and after connecting the data)
Additional info would bve helpful:
a) Screenshot from your crash
b) Data-Upload if you are allowed to show that
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
in reply to: 40032831983
Program - 2012 Map 3D W/Raster Design SP1,64bit
Workstation - Windows 7 Enterprise SP1, Dell T5500, E5607, 8Gb.
Crashes/Fatal error anytime I attempt to select anythnig using grips.. Blocks, plines, text, anything..
Just started it this morning... Last week everything was great....
try to login to your pc/to your Windows with another user-account, then start AutoCAD-Map .... same problem?
What has changed on your pc since it was fully functional last time? Any updates from Windows? Was there anything installed in the meantime?
- alfred -
Alfred NESWADBA
Tryed that, didn't make any disfference...
Reset the system var "GRIPS" to 0 then back to 1.... Fixed it.. don't know why...
Weird... but not surprising..
Thanks for trying to help!!!!
Thank you for the feedback!
I also don't understand the reason why this helped, but now we know that it's worth to try it! 😉
- alfred -
Alfred NESWADBA
”Boost
