AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Fatal Error Exporting to Shape
3 REPLIES 3
511 Views, 3 Replies
Just recently I keep getting this error when trying to use Map, Tools, Export to shape format....
Fatal Error-Unhandled e06d736h Exception at 7c812aebh
any info will help...
3 REPLIES 3
Hi rg7603,
I am getting the same error when I try to insert a georeferenced tiff with a corresponding tfw file. This started showing up after I installed Civil 3D 2009 side by side with C3D 2008.
Since I cannot uninstall either version yet, I have been using a lisp routine to bring in my tiffs, but it is very annoying!
I've had various problems with exporting polygons over time. Do you have the object enablers installed for Raster Design? Civil Design?
-monkey5672
Sure do. I haven't tried to export polygons, just trying to import\insert a geotiff using a TFW file when I get this error
”Boost
