AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Failed to connect to WMS services - AutoCAD map 3D
20 REPLIES 20
Message 1 of 21
5831 Views, 20 Replies
I cant connect to WMS services on AutoCAD map 3D, getting this message:
Faild to connect.
Faild to open FDO connection.
Couldnt resolve Proxy name
Works out fine in ArcGIS and other mapping software in the office.
Anybody knows wich port AutoCAD is using for WMS-services?
/Henrik
20 REPLIES 20
Message 2 of 21
mike.sharp
What connection string are you using to connect to the WMS service?
Message 3 of 21
in reply to: mike.sharp
Ive tried about 5 different.
For example:
http://demo.cubewerx.com/demo/cubeserv/cubeserv.cgi?CONFIG=main&SERVICE=WMS&?VERSION=1.1.1&a...
http://wms.geonorge.no/skwms1/wms.matrikkel.v1?
Without success
It feels like it is some kind of port/firewall issue
/Henrik
Message 4 of 21
mike.sharp
From your Get Capabilities request when posted in a web browser (remove quotes)
"http://demo.cubewerx.com/demo/cubeserv/cubeserv.cgi?CONFIG=main&SERVICE=WMS&?VERSION=1.1.1&REQUEST=G..."
I used the Online Resource link found in the returned xml document (remove quotes)
"http://demo.cubewerx.com/demo/cubeserv/cubeserv.cgi?CONFIG=main&"
as the connection string in AutoCAD Map 3D-2012 and WMS Version 1.1.1.
This gave me the connection to the WMS server and the list of layers to choose from.
Message 5 of 21
Yup! I can make it work outside of our network aswell.
But the question was wich port AutoCAD is using for WMS:-)
Regards Henrik
Message 6 of 21
mike.sharp
I guess I don't have a clue on that.  I just assumed it was some basic port like 80 or 8080.  We have a pretty tight firewall to go through and have not had any issues with Map or ArcGIS.  Sorry I could not help.
Message 7 of 21
NateMoore
Does this help? http://knowledge.autodesk.com/support/autocad-map-3d/troubleshooting/caas/sfdcarticles/sfdcarticles/...
Nate Moore, GISP
Geospatial Premium Support Specialist
Global Services
Autodesk, Sarl
Message 8 of 21
in reply to: NateMoore
Great! Works fine now.
Thanks a lot
//Henrik
Message 9 of 21
I am having an almost identical issue with AutoCAD Map 3D 2012 [Failed to connect; Failed to open FDO connection; Unable to connect to host]
My IT folks are stumped at the present moment.  What exactly did you do to correct the issue?  Any/all infomation you have to offer is very much appreciated.  Thanks in advance.
V
Message 10 of 21
braudpat
Hello
1) Can you try with a MAP 2013 or MAP 2014 ?
2) A lot of problems can come from proxy Server !?
3) Problems can come from login/password when you have a mix of layers : some unprotected, some protected by login/password !?
Bye, Pat
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 11 of 21
antoniovinci
Please paste here that WMS address, thx.
Message 12 of 21
in reply to: antoniovinci
Thanks all for the timely responses.  What I have done thus far...
All I got is MAP 2012 (so "no go" on trying the WMS out MAP 2013 nor 2014) - so I installed SP2 for MAP 2012
Created the system variable all_proxy, leveraging both flavors of IP Address + port numbers recommnded here:  http://knowledge.autodesk.com/support/autocad-map-3d/troubleshooting/caas/sfdcarticles/sfdcarticles/...
Using this WMS:  http://demo.cubewerx.com/demo/cubeserv/cubeserv.cgi?
Getting now:  "Failed to connect.  Failed to open FDO connection.  Couldn't resolve proxy name"
Thoughts, suggestions?
Message 13 of 21
antoniovinci
I've checked it out in Qgis, it seems alive and kicking:
In the attached file here's the getCapabilities report, maybe somebody will figure out a solution for you, sir.
Message 14 of 21
braudpat
Hello
Thks for the WMS address !
I get a FDO error when trying to "Add to the FDO Map" any WMS layer !!
And I am running with MAP 2014, so I think it will be EASIER to use QGIS !?
Bye, Pat
Patrice BRAUD
Message 15 of 21
olivier.eckmann
in reply to: braudpat
Hi
No problem with my MAP 2012 (if I assign EPSG 4326 to my DWG)
Olivier
Message 16 of 21
It should not matter, Monsieur: try to set ESPG:32632 (i.e. UTM84 zone 32N) and you'll get the Corsica Island...
Message 17 of 21
Hi Antonio,
I've tried to assign RGF93.CC49 (french CS corresponding to PARIS) or Lambert93 (corresponding to whole France), and I obtain an error message :
"Coordinates transformation failed for 398 objects"
Nothing is added to the map.
Olivier
Message 18 of 21
Salut Olivier,
in my above attachment CUBEWERX.ZIP you have all the EPSGs supported by that WMS server...
Message 19 of 21
Thanks all for the support....
It is not the WMS per se (I tried it out in ArcGIS via the GCRS = EPSG 4326 and all worked fine), but rather getthing through to the WMS... getting beyond the "Failed to connect; Failed to open FDO connection; Unable to connect to host" issues in AutoCAD Map.
Any thoughts, recommendations, re: "the next step"?
Message 20 of 21
olivier.eckmann
Have you tried solution given in 7th post?
@Antonio : I don't know anything in WMS, but what you say means that it's the WMS server which make raster reprojection, not the software which visualizes the tiles? If it's right, that means, if I use a custom CS I can't use any WMS service?
Olivier
”Boost
