AutoCAD Map 3D General Discussion
Active Member
Henrik_RRR
Message 1 of 21 (1,920 Views)
Failed to connect to WMS services - AutoCAD map 3D
1920 Views, 20 Replies
08-30-2011 07:54 AM
I cant connect to WMS services on AutoCAD map 3D, getting this message:
Faild to connect.
Faild to open FDO connection.
Couldnt resolve Proxy name
Works out fine in ArcGIS and other mapping software in the office.
Anybody knows wich port AutoCAD is using for WMS-services?
/Henrik
Active Member
mike.sharp
Message 2 of 21 (1,904 Views)
Re: Failed to connect to WMS services - AutoCAD map 3D
08-31-2011 12:23 PM in reply to: Henrik_RRR
What connection string are you using to connect to the WMS service?
Active Member
Henrik_RRR
Message 3 of 21 (1,892 Views)
09-01-2011 12:35 AM in reply to: mike.sharp
Ive tried about 5 different.
For example:
http://demo.cubewerx.com/demo/cubeserv/cubeserv.cgi?CONFIG=main&SERVICE=WMS&?VERSION=1.1.1&a...
http://wms.geonorge.no/skwms1/wms.matrikkel.v1?
Without success
It feels like it is some kind of port/firewall issue
/Henrik
Active Member
mike.sharp
Message 4 of 21 (1,883 Views)
09-01-2011 04:21 AM in reply to: Henrik_RRR
From your Get Capabilities request when posted in a web browser (remove quotes)
"http://demo.cubewerx.com/demo/cubeserv/cubeserv.cgi?CONFIG=main&SERVICE=WMS&?VERSION=1.1.1&REQUEST=G..."
I used the Online Resource link found in the returned xml document (remove quotes)
"http://demo.cubewerx.com/demo/cubeserv/cubeserv.cgi?CONFIG=main&"
as the connection string in AutoCAD Map 3D-2012 and WMS Version 1.1.1.
This gave me the connection to the WMS server and the list of layers to choose from.
Active Member
Henrik_RRR
Message 5 of 21 (1,853 Views)
09-06-2011 06:19 AM in reply to: mike.sharp
Yup! I can make it work outside of our network aswell.
But the question was wich port AutoCAD is using for WMS:-)
Regards Henrik
Active Member
mike.sharp
Message 6 of 21 (1,840 Views)
09-06-2011 12:32 PM in reply to: Henrik_RRR
I guess I don't have a clue on that.  I just assumed it was some basic port like 80 or 8080.  We have a pretty tight firewall to go through and have not had any issues with Map or ArcGIS.  Sorry I could not help.
Product Support
NateMoore
Message 7 of 21 (1,820 Views)
09-07-2011 12:16 PM in reply to: Henrik_RRR
Does this help? http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=11794193&linkID=9240857
Nate Moore, GISP
Geospatial Premium Support Specialist
Global Services
Autodesk, Sarl
Active Member
Henrik_RRR
Message 8 of 21 (1,773 Views)
09-15-2011 04:14 AM in reply to: NateMoore
Great! Works fine now.
Thanks a lot
//Henrik
vince.mattes
Message 9 of 21 (521 Views)
02-17-2014 10:50 AM in reply to: Henrik_RRR
I am having an almost identical issue with AutoCAD Map 3D 2012 [Failed to connect; Failed to open FDO connection; Unable to connect to host]
My IT folks are stumped at the present moment.  What exactly did you do to correct the issue?  Any/all infomation you have to offer is very much appreciated.  Thanks in advance.
V
braudpat
Message 10 of 21 (514 Views)
02-17-2014 11:31 AM in reply to: vince.mattes
Hello
1) Can you try with a MAP 2013 or MAP 2014 ?
2) A lot of problems can come from proxy Server !?
3) Problems can come from login/password when you have a mix of layers : some unprotected, some protected by login/password !?
Bye, Pat
Bye, Pat
You are not logged in.
Ask the Community
