AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
FDO error to check-in features
4 REPLIES 4
andy62
688 Views, 4 Replies
When I try to check-in a feature to table that is stored on SQL Server I get this message: "'FdoSpatialGridTransform::CalculateParameters': The resolution is too large (> 0.1) for the extents."
Has anyone ever seen this?
Any suggestions are greatly appreciated.
Andrea
4 REPLIES 4
in reply to: andy62
Andrea
I get this same error when trying to bulk copy from an SDF file to SQL Server Spatial.
Did you ever find the cause/resolution?
Arben.Sylejmani
in reply to: andy62
Hi
Did you finde anything regardin this error 'FdoSpatialGridTransform::CalculateParameters':The resolution is too large (>0.1) for the extents
I have the same problem with Bulk Copy from dwg to Sql Server?
in reply to: Arben.Sylejmani
I have not figured out the cause or the resolution.
Arben.Sylejmani
in reply to: andy62
Hi
”Boost
