Yes you can run Inventor and Map3D on the same workstation. You just need to
install them in the correct order and following the directions in the readme
for the installs. Install as Admin, turn off all virus checkers before
installing, close any other programs running, and a few other items you need
to follow depending on your OS and networks etc.
Murph
wrote in message news:5863221@discussion.autodesk.com...
Yes, I have Autodesk Inventor installed. Can I not run both Inventor and Map
3D on the same system?
