AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Exprot joined and queried data to plain CAD
3 REPLIES 3
neilyj666
355 Views, 3 Replies
I'm finding Map particularly infuriating today......(more so than usual)...!!!!
I have connected to various shp files and then queried by circle to get my area of interest. I now want to "export" this data as plain AutoCAD entities but can't seem to do it with any success.
Can anyone point me in the correct direction...??
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
3 REPLIES 3
antoniovinci
in reply to: neilyj666
Hmm, sounds like you wanna joke with us, man: a power-user with 1630 posts is NOT allowed to ask this kind of questions.. Anyway, let's joke:
1] _MAPIMPORT those shapes
2] _MAPTRIM everything by circle
3] finally _WBLOCK the remaining objects, or SAVE AS dxf rel.12
neilyj666
in reply to: antoniovinci
1630 posts in total - but considerably fewer relating to MAP problems....!!!!
I've done the first 2 steps: it's getting the shp files data to a CAD format that's causing the problem -  I tried the _mapexportcurrentmaptodwg but nothing is getting exported.
EDIT - Just tried in  2012 and _mapexportcurrentmaptodwg worked fine on a local drive and have now tried in 2013 with a local drive which also worked fine.
Conclusion - probable network access issue causing the export to fail..??
parkr4st
after the connect and add by query. map explorer, right click the layer and export data to sdf.  you can then map import the sdf with create OD  to cad
”Boost
