Hi Warren,
Thanx for the quick response. In addition to Map 5.0 we have purchased
several licenses of 2002, I assume the 2002 E.T. will work in Map 5.0 as
well? If this is the case, then I will definitely do some research to
figure this out, otherwise, I am going back to vanilla 2002.
Thanx again,
Rob
"Warren Medernach" wrote in message
news:98AE30EB8A5765284BF5A5A1AA08D51F@in.WebX.maYIadrTaRb...
> Hello Rob.
> The short answer...
> No, none of the 2002 series of products include the Express Tools.
> If you have E.T. from AutoCAD 2000/2000i release, these will work on 2002.
> There are many threads and a few tech docs on this. Just do some
searching
> through the N/Gs.
> Hope this helps
> Warren M.
> "Rob Outman" wrote in message
> news:3CB0C1A8D709FEDDCD3EC92116E5D061@in.WebX.maYIadrTaRb...
> > Does anyone know if AutoDesk Map 5.0 comes with the express tools found
in
> > AutoCAD 2002? We recently installed (full install) map 5.0 and there is
no
> > Express tools directory. I can also find no express tools menus etc...
> > Anyone know what the deal is? I was under the assumption that AutoDesk
> Map
> > 5.0 was EXACTLY like Acad2002 with the additional map features.
> > TIA,
> > Rob
