deanlimper wrote:
Unknown command "MAPEXOPRT". Press F1 for help.
The right command is _MAPEXPORT, sir.
There is also a short way, you can use the list command, copy all, then paste it into a txt file and delete all the words that are not important, then saved in csv format.
Dear Friends,
i want to extract X,Y,Z from polyline but easiest. i just select the line and used LI Command for list, it's asking 30 times to enter and even not able to find full data easily, as well as after copying from list, have to delet extra txt and have to arrange separately xyz., as you've given the lisp locaiton at : http://www.dotsoft.com/freestuff.htm i am not able to find that LISP file for xyz txt file etc.
please can anyone send me quickly to Abuhasan3k@gmail.com
Many Thanks,
Maybe it will help: http://lee-mac.com/ptmanager.html
Many Thanks Dear,
It's very helpful and easy and with Other Options...very nice
Thanks once again..
Problem to get the data from 3D Polylines/Points/Blocks which should be in original xyz form. how to extract data from all these types?
Answer is to uplaod a Lisp file and use as mentioned in website and you can play around for other options.
Thanks & Regards,
Student
see attached file .rar.
Save your file in dxf format.
This small saftware export all the entity in xyz coordiantes in a txt file.
Try, and let me now
