AutoCAD Map 3D General Discussion
allensam12
Message 1 of 15 (354 Views)
Export to Shp Autocadmap 2013
354 Views, 14 Replies
06-04-2013 10:05 AM
I am currently using AutoCad Map3d 2013. I am trying to export some features to esri shape file. When I use the export command it does not export all the features, only a few of them. I tried each different way point, line, polygon (treat closed polylines as polygons). I just did this the other day and worked out fine. PLEASE HELP
*Expert Elite*
antoniovinci
Message 2 of 15 (351 Views)
Re: Export to Shp Autocadmap 2013
06-04-2013 10:25 AM in reply to: allensam12
The _MAPEXPORT command creates a single-class shape, one for each vector type: points, lines, polygons, texts.
In oher words, you gotta repeat that command up to four times, sir.
allensam12
Message 3 of 15 (342 Views)
06-04-2013 11:45 AM in reply to: antoniovinci
The features have to be checked out and it will work
allensam12
Message 4 of 15 (318 Views)
06-04-2013 09:02 PM in reply to: allensam12
So when I open a new dwg and import the new shapefile that was just created from previous drawing and view the data table none of the information is there as it was in the orgininal.
HELP WHAT AM I DOING WRONG PLEASE?
*Expert Elite*
antoniovinci
Message 5 of 15 (310 Views)
06-05-2013 12:24 AM in reply to: allensam12
*Expert Elite*
Murph
Message 6 of 15 (302 Views)
06-05-2013 04:11 AM in reply to: allensam12
Are you exporting autocad enitites or features from a data connection?
If you are using data connect and checking out the feature then it creates a dumb Autocad enitie with NO data attached. If you are using a connected data file and need shp then look at the bulk copy command.
Murph
Supportting the troops daily.
*Expert Elite*
Murph
Message 7 of 15 (300 Views)
06-05-2013 04:13 AM in reply to: antoniovinci
antoniovinci wrote:
Antoniovici, I don't know what it is but when you link in images all I get are boxes with X in them.
Murph
*Expert Elite*
antoniovinci
Message 8 of 15 (294 Views)
06-05-2013 05:17 AM in reply to: Murph
Sounds like your firewall is blocking Gifs animated: here the explicit URL of the above one
http://novarese.t15.org/autodesk/mapimport.gif
allensam12
Message 9 of 15 (289 Views)
06-05-2013 06:21 AM in reply to: Murph
Features from a data connection. I have been tryin the bulk copy command and it does the same thing I know Im not doing something right.
I also cannot see the pictures.
allensam12
Message 10 of 15 (285 Views)
06-05-2013 07:06 AM in reply to: allensam12
Thank everyone for their input Okay I finally got it to work usinig the bulk command. steps for this
1) Be sure to export the schema of the data base file that you want to use somewhere where you will be able to find it.
2) In Map explorer select the schema and create a shp file, delete default schema and import the schema you just exported from the feature source.
3) While your still in map explorer bulk copy the schema from the feature source you exported the schema from select all the boxes under ignore the following errors.
4) Be sure to to name the files the same.
You are not logged in.
Announcements
Need installation help?
Ask the Community
