I am currently using AutoCad Map3d 2013. I am trying to export some features to esri shape file. When I use the export command it does not export all the features, only a few of them. I tried each different way point, line, polygon (treat closed polylines as polygons). I just did this the other day and worked out fine. PLEASE HELP
The _MAPEXPORT command creates a single-class shape, one for each vector type: points, lines, polygons, texts.
In oher words, you gotta repeat that command up to four times, sir.
So when I open a new dwg and import the new shapefile that was just created from previous drawing and view the data table none of the information is there as it was in the orgininal.
HELP WHAT AM I DOING WRONG PLEASE?
@allensam12 wrote:The features have to be checked out and it will work
Are you exporting autocad enitites or features from a data connection?
If you are using data connect and checking out the feature then it creates a dumb Autocad enitie with NO data attached. If you are using a connected data file and need shp then look at the bulk copy command.
@antoniovinci wrote:
Antoniovici, I don't know what it is but when you link in images all I get are boxes with X in them.
Murph wrote:
I don't know what it is but when you link in images all I get are boxes with X in them.*******************************************************************************************************
Sounds like your firewall is blocking Gifs animated: here the explicit URL of the above one
http://novarese.t15.org/autodesk/mapimport.gif
Features from a data connection. I have been tryin the bulk copy command and it does the same thing I know Im not doing something right.
I also cannot see the pictures.
Thank everyone for their input Okay I finally got it to work usinig the bulk command. steps for this
1) Be sure to export the schema of the data base file that you want to use somewhere where you will be able to find it.
2) In Map explorer select the schema and create a shp file, delete default schema and import the schema you just exported from the feature source.
3) While your still in map explorer bulk copy the schema from the feature source you exported the schema from select all the boxes under ignore the following errors.
4) Be sure to to name the files the same.
Murph wrote:
No firewall and even om the mobile side no imagine.
What about now..?
Murph wrote:
For the first one anyways.
I cannot explain that.
Since 2011 I was attaching helpful images in my posts, but if you say that in Usa they are not visible, seems like I wasted my time...
