AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Export to Shp Autocadmap 2013
14 REPLIES 14
Message 1 of 15
allensam12
1036 Views, 14 Replies
I am currently using AutoCad Map3d 2013. I am trying to export some features to esri shape file. When I use the export command it does not export all the features, only a few of them. I tried each different way point, line, polygon (treat closed polylines as polygons). I just did this the other day and worked out fine. PLEASE HELP
Tags (1)
14 REPLIES 14
Message 2 of 15
antoniovinci
in reply to: allensam12
The _MAPEXPORT command creates a single-class shape, one for each vector type: points, lines, polygons, texts.
In oher words, you gotta repeat that command up to four times, sir.
Message 3 of 15
allensam12
in reply to: antoniovinci
The features have to be checked out and it will work
Message 4 of 15
allensam12
So when I open a new dwg and import the new shapefile that was just created from previous drawing and view the data table none of the information is there as it was in the orgininal.
HELP WHAT AM I DOING WRONG PLEASE?
Tags (1)
Message 5 of 15
antoniovinci
Message 6 of 15
Murph_Map
Are you exporting autocad enitites or features from a data connection?
If you are using data connect and checking out the feature then it creates a dumb Autocad enitie with NO data attached. If you are using a connected data file and need shp then look at the bulk copy command.
Murph
Supporting the troops daily.
Message 7 of 15
Murph_Map
@antoniovinci wrote:
Antoniovici, I don't know what it is but when you link in images all I get are boxes with X in them.
Murph
Message 8 of 15
antoniovinci
in reply to: Murph_Map
Sounds like your firewall is blocking Gifs animated: here the explicit URL of the above one
http://novarese.t15.org/autodesk/mapimport.gif
Message 9 of 15
allensam12
Features from a data connection. I have been tryin the bulk copy command and it does the same thing I know Im not doing something right.
I also cannot see the pictures.
Message 10 of 15
allensam12
Thank everyone for their input Okay I finally got it to work usinig the bulk command. steps for this
1) Be sure to export the schema of the data base file that you want to use somewhere where you will be able to find it.
2) In Map explorer select the schema and create a shp file, delete default schema and import the schema you just exported from the feature source.
3) While your still in map explorer bulk copy the schema from the feature source you exported the schema from select all the boxes under ignore the following errors.
4) Be sure to to name the files the same.
Message 11 of 15
Murph_Map
No firewall and even om the mobile side no imagine.
Murph
Message 12 of 15
antoniovinci
What about now..?
Message 13 of 15
Murph_Map
That works. 🙂 For the first one anyways.
Murph
Message 14 of 15
antoniovinci
I cannot explain that.
Since 2011 I was attaching helpful images in my posts, but if you say that in Usa they are not visible, seems like I wasted my time...
Message 15 of 15
fieldguy
They work fine in Canada - thank you very much!.  Keep up the good work!
”Boost
