AutoCAD Map 3D General Discussion
Distinguished Contributor
bingeomatics
Message 1 of 13 (445 Views)
Export to Shape
445 Views, 12 Replies
08-28-2012 10:47 PM
Hello, colleagues!
How can to export my SDF file to ESRI Shape file? In AutoCAD Map menu have a commands, but those works only for drawing objects. Have any way to export SDF to Shape?
Thanks all? who can help me!
Binnat Khalilov
Alfred.NESWADBA
Message 2 of 13 (442 Views)
Re: Export to Shape
08-28-2012 11:10 PM in reply to: bingeomatics
two options:
  • use _MAPIMPORT (>>>details<<<) to import the SDF-file (don't forget to import the attributive data to objectdata .... and then use command _MAPEXPORT (>>>details<<<) to create a SHP.
  • use _MAPCONNECT to get the SDF referenced into your drawing. Then create an empty SHP +the structure for it (using schema-creation functionality(>>>details<<<)). When this part is finished you can use bulk-copy (>>>details<<<) to transfer the content from SDF to SHP.
Good luck, - alfred -
Alfred NESWADBA
bingeomatics
Message 3 of 13 (437 Views)
Re: Export to Shape
08-28-2012 11:26 PM in reply to: Alfred.NESWADBA
Thank you very much!
Binnat Khalilov
bingeomatics
Message 4 of 13 (357 Views)
Re: Export to Shape
09-12-2012 04:19 AM in reply to: bingeomatics
Hi!
I tried to copy from SDF to SHP, but I can't. When I can't apply  Bulk copy command? What problem must be?
error
Binnat Khalilov
Murph
Message 5 of 13 (341 Views)
Re: Export to Shape
09-12-2012 02:55 PM in reply to: bingeomatics
A SDF file can contain point, line and polygon features all in the same dwg. Most likey your SDF is set up as multiple type features. You might want to try FDO2FDO from SL-King its a little more forgiving.
http://www.sl-king.com/fdo2fdo/fdo2fdo.html
Murph
Supportting the troops daily.
bingeomatics
Message 6 of 13 (335 Views)
Re: Export to Shape
09-12-2012 09:48 PM in reply to: Murph
Thanks, Murph! I will try...
Binnat Khalilov
bingeomatics
Message 7 of 13 (334 Views)
Re: Export to Shape
09-12-2012 10:00 PM in reply to: bingeomatics
Murph, thanks, it works goog, I have exported and finished sucsessfully. But it don't exports coordinate systems informations. How can I solve this problem. Did you used FDO2FDO?
Binnat Khalilov
Alfred.NESWADBA
Message 8 of 13 (329 Views)
Re: Export to Shape
09-12-2012 10:54 PM in reply to: bingeomatics
the coordinate system is stored in a separate PRJ-file (same name like SHP, DBF, SHX, but other extension).
If you don't have that file and you need it, create an empty shape winthin a drawing with assigned coord-sys, that will also create a PRJ-file then. Use this file and rename it to the name of your SHP-data.
To the above message: I have seen that also when converting an SDF or SQLite to a SHP even when the sources where set to a single geometrytype (POLYGON) and not multiple-geom-types.
- alfred -
Alfred NESWADBA
bingeomatics
Message 9 of 13 (323 Views)
Re: Export to Shape
09-12-2012 11:26 PM in reply to: Alfred.NESWADBA
Thank you, Alfred.
Binnat Khalilov
bingeomatics
Message 10 of 13 (322 Views)
Re: Export to Shape
09-12-2012 11:27 PM in reply to: bingeomatics
But I want to know, is it that I did wrong anything in AutoCAd Map while exporting?
Binnat Khalilov
You are not logged in.
Ask the Community
