AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Export to PowerPoint
4 REPLIES 4
msprouffske
292 Views, 4 Replies
What is the format or method to export a map project to Microsoft PowerPoint as a slide?
4 REPLIES 4
in reply to: msprouffske
Screen capture to a BMP works although the file
size is large. Screen capture to GIF is good too.
David
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
What
slide?
Rather than do a screen capture, use the PublishToWeb JPG or the
Independent JPEG Group JFIF (JPEG compression) plotter. If you don't
find these available, add them through the Autodesk plotter manager in
the control panel. If the map is going to take up most of the slide, I
use the Sun Hi-Res (1600 x 1280 pixels). This creates a jpg file that
is much smaller than a bmp.
Rick
There is a third party utility called BetterWMF that does a VERY nice
job on this. I use it on a daily basis. Best $100 that I ever spent
here on AutoCAD. (shameless plug!) They have a free working demo.
www.furix.com
You will have resolution independent vector based .wmf files to insert!
If you plan to do this on a regular basis you NEED this plugin.
Another good way to do this is to use the command
"saveimg".  The resulting dialog box lets you specify image resolution and
file type.
What
slide?
”Boost
