I've searched the forum but had no luck on these two questions:
1) we're using infrastructure map server 2012 and maps are a mix of FDO layers and DWF files exported from Map 3D. Mapguide Studio does not allow you to style DWF layers (we want them all in th color black). Is there an easy way to export a DWF in all black color without first having to select all layers, change color, export and then change them back?
2) When right-clicking and selecting properties of an FDO layer, is there a way to hide certain properties? we have calculated columns in our features sources which the user in Map 3D does not need to see.
thanks!
Solved by tmblackflag. Go to Solution.
FYI,
on #1 i found an override property that lets you export to monochrome
on #2, it is not possible but you can make properties read only in the schema editor.
