Hi, I'm new of autocad map 3d and I have a problem. I have created a map using some DTED files and now I need to use it in 3ds max, so I must export it in .fbx format but I'm not able to do this, because Autocad says to me that I must convert the map in 3D object. So my question is: What I have to do to export the map in .fbx format??
Thank you
Hello from France
Welcome to the Autodesk/AutoCAD Forums !
If I remember well, an Export (FBX format) can be done only with Real 3D ACAD Objects
Real means : ACAD 3D Volumes and maybe ACAD 3D Surfaces ...
Sorry, Bye, Pat
Patrice BRAUD
First of all thank you for your reply,so I can't do that? When I try to export the map in .fbx format the program says to me that I must convert the 2D object in a 3D object by increasing the thickness and setting it to a different value from 0. How can I do that?
Thank you
Lorenzo
you can try to create elevation contours with Map3D, import then these contours as AutoCAD-polylines, save that as drawing and import these polylines then to 3DS-Max.
Within 3DS you can then create a new surface based on that polylines.
Good luck, - alfred -
