AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Export a portion of a Map File to CAD
2 REPLIES 2
wadeburcham4557
994 Views, 2 Replies
I’m trying to ultimately create a Civil 3D surface, from shape files. I only want a portion of the contours to be exported to CAD, since the file is so big.  I’m thinking there must be a easy way to simply select an area and export that area to CAD, then build the a surface from the CAD files.  I’m having problems figuring out how to do that.
2 REPLIES 2
parkr4st
in reply to: wadeburcham4557
If you wanna load only a subset of your huge shapefile, upon _MAPIMPORTing check one of these 2 options:
”Boost
