I’m trying to ultimately create a Civil 3D surface, from shape files. I only want a portion of the contours to be exported to CAD, since the file is so big. I’m thinking there must be a easy way to simply select an area and export that area to CAD, then build the a surface from the CAD files. I’m having problems figuring out how to do that.
Solved by parkr4st. Go to Solution.
I believe you need this from Murph
http://map3d.wordpress.com/2007/09/26/contours-from-shape-files-with-elevations/
Dave
If you wanna load only a subset of your huge shapefile, upon _MAPIMPORTing check one of these 2 options:
