AutoCAD Map 3D General Discussion
Valued Contributor
wadeburcham4557
Message 1 of 3 (215 Views)
Export a portion of a Map File to CAD
215 Views, 2 Replies
01-29-2014 10:46 AM
I’m trying to ultimately create a Civil 3D surface, from shape files. I only want a portion of the contours to be exported to CAD, since the file is so big.  I’m thinking there must be a easy way to simply select an area and export that area to CAD, then build the a surface from the CAD files.  I’m having problems figuring out how to do that.
Valued Mentor
parkr4st
Message 2 of 3 (199 Views)
Re: Export a portion of a Map File to CAD
01-29-2014 03:05 PM in reply to: wadeburcham4557
antoniovinci
Message 3 of 3 (183 Views)
01-29-2014 10:58 PM in reply to: wadeburcham4557
If you wanna load only a subset of your huge shapefile, upon _MAPIMPORTing check one of these 2 options:
You are not logged in.
Ask the Community
